Quick fuel tank question
I'm hoping on getting the orginal fuel tank back in the Brat this week and just had a question about some modifications made to it by the last owner, it seems when he got it there was junk in the tank and it was clogging up fuel filters and the lines, so he installed another tank in the bed to run off of, at some point before he did this on the drivers underside of the tank he added a 90 deg. brass fitting with some goo holding it on. I'm guessing he had a fuel line hooked up to it, not sure what that would've solved but he did it anyway.
I'm just curious if this was the orginal location for a drain plug and if so would there be like a threaded nut on the inside of the tank for the plug to go into, I really don't like the idea of this fitting smacking something while driving.
