Syonyk Posted October 21, 2006 Share Posted October 21, 2006 I can't get the lower passenger's side bellhousing bolt off - I can't get a good angle on it, or enough force. Is there a trick to this? Removing the starter, or something? And, also, what do I lift the engine with? I'm planning to use the rear brace, but the front of the engine - should I put the power steering brace back on to lift from that, or is there something else? -=Russ=- Link to comment Share on other sites More sharing options...
ShawnW Posted October 21, 2006 Share Posted October 21, 2006 Power steering bracket sounds right. It should have a hole for a chain loop. Sometimes you have to pull the axle to get a socket on it but I use a 14MM wobble socket, extension and a lot of cursing sometimes. Link to comment Share on other sites More sharing options...
Syonyk Posted October 21, 2006 Author Share Posted October 21, 2006 We were able to get it, finally. Engine's sitting on the lift. Time to go test drive a Forester XT. -=Russ=- Link to comment Share on other sites More sharing options...
Syonyk Posted October 22, 2006 Author Share Posted October 22, 2006 And Subaru gave me the WRONG REAR MAIN SEAL! *stabs* Next question: When putting the front main seal back in, I got it ~1/8" below flush. Is this a problem, or is that where it's supposed to be? Also, with the rear main, should it be flush or slightly deeper than flush, or "as far in as I can get it"? And... cam seals, same question. They're flush right now. -=Russ=- Link to comment Share on other sites More sharing options...
98sub2500leg Posted May 10, 2009 Share Posted May 10, 2009 (edited) I can't get the lower passenger's side bellhousing bolt off - I can't get a good angle on it, or enough force. Is there a trick to this? Removing the starter, or something? And, also, what do I lift the engine with? I'm planning to use the rear brace, but the front of the engine - should I put the power steering brace back on to lift from that, or is there something else? -=Russ=- I just got done doing it, I had the same ? from yesterday. You don't need to remove the axel to get to the lower nuts (I have a 98 Outback 2.5L and they are nuts). Use a 3/8" breaker bar (non ratcheting type with universal joint on the end) with a short 6 pt 14mm socket and something like a 2' piece of 3/4" black pipe as a cheater bar on the breaker bar. I did remove the starter bolt (drivers side) and also the passenger side upper bolt. I am having trouble separating the two now with everything cleared. Edited May 10, 2009 by 98sub2500leg Link to comment Share on other sites More sharing options...
