Ranger83 Posted November 15, 2006 Share Posted November 15, 2006 Have any of you ever taking you Subaru's out on a track? It is suprising how far you can push it before it actually understeers. //// Mr. Expert does not seem to be aware that the XT and H6 used the VTD drive system, which puts 55% of the torque to the rear by default. Most Gen III wagon drivers also put 1-2 psi more tire pressure in the front, which also helps balance the car. If you watch the video at http://www.youtube.com/watch?v=eYKJIVajAIE you'll see there's little understeer evident - it's quite neutral. Quote Link to comment Share on other sites More sharing options...
rlsimpso Posted November 16, 2006 Share Posted November 16, 2006 The slight torque split combined with more tire pressure in the front end balances the car. That is great. So? I'm an expert because I have some idea of how to control a car in a turn? Where is my merit badge? I guess I should just make one sentence statements without demonstrating any knowledge about the subject. Here is a link:http://www.youtube.com/watch?v=XJemif6bSCQ Notice the mild understeer. This vehicle is actually accelerating in the turns. The SVX has the VTD too, BTW. Flames are for ricers. Lighten up:-p . Quote Link to comment Share on other sites More sharing options...
