gcleeton Posted November 24, 2006 Share Posted November 24, 2006 I have cleaned/repaired/replaced my 96, 98, 99 Legacy window switches from time to time, but now I need advice please - On my 96 Legacy, the PAIR of passenger side windows will not go down, only up, when operated from the passenger side. They will go up and down when operated from the driver side? Gil Quote Link to comment Share on other sites More sharing options...
Richard1296 Posted November 24, 2006 Share Posted November 24, 2006 Its got to be the switches, but the passenger door switches may be wired back to the drivers side. Check all the switches. Usually the switches provide the ground, with power at the motors all the time. Richard Quote Link to comment Share on other sites More sharing options...
gcleeton Posted November 24, 2006 Author Share Posted November 24, 2006 Would one ground cover both passenger switches, or are there separate grounds? Quote Link to comment Share on other sites More sharing options...
Richard1296 Posted November 25, 2006 Share Posted November 25, 2006 I'm not sure...I don't have a manual for 96. My experience is with my Mustangs. But I would be suspicious of the switches and their grounding at the drivers door. I do have a 90 Subaru service manual. It says first check main switch ( drivers door) and second check sub switches (passenger doors). It also says to check motor and regulator assembly but if it runs in one direction they should be OK. Only other thing would be a broken wire somewhere, but I'd still bet on the drivers door switch and wiring. Richard Quote Link to comment Share on other sites More sharing options...
Mark-O-Back Posted November 25, 2006 Share Posted November 25, 2006 My 97 has the kid proofing disable switch on the driver's door. Does your 96? Since the switches act on the ground side that ground must be routed through that switch, likely on a single wire. I'd check that switch and wire(s?) Let us know how how it works out ~ Mark ... Uh well I walked away thinking this post over and realized that the "kid switch" stops the action both up and down. Oh well, still curious at what you find. Quote Link to comment Share on other sites More sharing options...
gcleeton Posted November 26, 2006 Author Share Posted November 26, 2006 I squirted switch cleaner in the switches on the passenger side and then in the driver child lock window switch. The rear passenger window came to life. I put the front passenger window fully down and squirted silicon grease on the plastic sealing strip and the front passenger window works now. Thanks for all your valuable advice once again. Quote Link to comment Share on other sites More sharing options...
