loyale seats retrofit into 87 gl wagon?
the 91 loyale wagon has the strangler style seat belts,
and the seats have an additional bit of sheetmetal
which holds the buckle.
so the seat belt buckle is part of the seat :P
not bolted to the floor, like the 88 gl wagon.
can i remove this additional junk and bolt that loyale seat in
my good old fashioned ea82?
or is this stuff welded like the xt seats were?
spose i could go pull one of each and just bloody look.......
You want to put the Loyale seat in the GL, or vice versa?
I believe all EA82 seats are interchangeable. You only have to modify EA81 to fit EA82 and vice versa, and you can't use wagon/sedan seats in a hatch/3-door without losing the ablity to slide the seat forward (and get out of the back, unless you weigh less than 80 pounds and/or know yoga...but that's your passengers' problem :))
loyale seats into a gl
loyale seats are a freak though...
sun comes up, i will go get an answer, till then zzzzzzzzz
