tidd1340 Posted February 18, 2007 Share Posted February 18, 2007 Found this from another member..will it work in my 89gl without air cond.? Mine has 1-4 for speeds,this has 0-4..any ideas? Link to comment Share on other sites More sharing options...
ellets Posted February 18, 2007 Share Posted February 18, 2007 It will likely work but are you sure it is switch? Resistor pack failure is a common thing in subies. Link to comment Share on other sites More sharing options...
tidd1340 Posted February 18, 2007 Author Share Posted February 18, 2007 no im sure its the switch..if you put upwards pressure on the knob it works in all 4 speeds. if not it only works on speed 3. Link to comment Share on other sites More sharing options...
daeron Posted February 18, 2007 Share Posted February 18, 2007 I want that setup!!! a separate switch, both for AC on function, AND recirculate!?!??? thats like, NORMAL!! I had seen this on australian market soobs, IIRC, but nothing LHD before. It might take some doing, but since you have no AC then the AC controls themselves would be ignorable.. as for the fan, make sure you nab the plugs that go to all of that, just to be sure. That way, if you have to do any splicing, at least you will have plugs that fit your new switches. Link to comment Share on other sites More sharing options...
