1.8 TURBO EA82 ej18 impreza turbo conversion
hi does someone know if the turbo off a EA82 will fit onto a ej18 engine out of a impreza will it work ?:burnout:
i mean will the ecu have to be changed are the exhaust manifolds the same ect
There is nothing between the two cars that is a "bolt-on", everything that you try to fit from the EA to the EJ will have to be modified.
The parts off of a WRX 2.0l turbo would be a much closer bolt on than the EA82t parts by miles.
very true. the displacement is about the only thing they have in common.
