Cruise control ECU connector
Where the F is that thing stored? I'm installing cruise into a 1995 legacy brighton. I've got the dash switch, wheels switch, vacuum pump, actuator, and both pedal switches installed. What I can't find is the black 20 pin connector that the CC ECU plugs into . All the other connectors were in the harness, so I would assume this one would be to. The two studs int he bottom of the steering column are there, so I assume that the CC ECU is mounted in the same spot as the Outback I took it out of.
Has anyone else had experience finding this connector? Is it taped into the harness? Is it hidden behind something?
attachment.php?postid=65482Picture stolen from CO_97 on subaruoutback.org
Answered my own question.
On 1995 models the 20pin black connector is behind the passenger side kick panel. It's kinda tucked up into the harness behind the kickpanel and held on with some masking tape.
Cruise control systems from later years work just fine with the 1995 cruise control. I plugged it in, cruise works great. Now to find a good spot to bolt it down on that side.
I think there's a scan of install instructions somewhere in picture galleries. Try searching. If you don't find anything - I can take a picture of install instructions that came with my kit.
