Don't put EA82's into the back of VWs
They are too wide. And the timing marks on the flywheel don't exist anymore. Even if they did, they wouldn't be visible due to the engine adapter.
In case anyone's wondering, the reason this looks so heinous is because it's been sitting for about 4 years, silently rusting. It does run, however.
You should buy it.
don't XT6s use timing marks on the crank pulley? If so, couldn't you use that for timing...
Aye, the 6's are set up that way. But, so are the EA-82's with the Spider intake on them.
That stuff is so rare here...
I've never seen an xt6, Knowing what it was, anyway.
I've seen 1 XT turbo, only cause a friend's mom owned it.
