2001 Outback-- Broken Fog Light
A stone must have destroyed my drivers side fog light. Subaru wants 250CDN for a replacement light. Anyone know where I can get an economical replacement??
Thanks
Yup, had the same thing happen to me... surprisingly enough, mine still works even though the bulb is exposed to the elements.
I plan on putting some HELLA 500's in once they finally burn out.
http://www.rallylights.com/
Not sure if there is an adapter for using the stock wiring harness, so I'm guessing you would have to cut and splice the wires.
Perfect! And the price is right.
Cheers
on our 01 OBW (when we had it) I noticed the lens was cracked, and started filling up with water. Dealer wanted $150 or so for 1... I said no, took it out and drilled a small drain hole in the back for the water, worked great for the 3+ years that we had it since I fixed it... :headbang:
