April 29, 200718 yr Hi all , not many XT6's in Australia so I'm wondering if anyone has pics of the 4 and 5 stud rear hubs . I need to know if its possible to drill the 5x100mm pcd stud holes in the 4 stud rear hubs if need be . Thanks Adrian .
April 29, 200718 yr Hi all , not many XT6's in Australia so I'm wondering if anyone has pics of the 4 and 5 stud rear hubs . I need to know if its possible to drill the 5x100mm pcd stud holes in the 4 stud rear hubs if need be . Thanks Adrian . Loyale2.7 drilled his to some smaller 4 bolt pattern. 4x110 maybe? Something smaller so I think it would be possible. But with 5 you'll end up with one or two of the holes being really close.
April 29, 200718 yr do ya know about the place some were in ozzy that convert legacy hubs to fit ea82 stuff? i know its pricey tho
April 29, 200718 yr Author I drew up a "clocking" diagram and noted 100 and 140mm PCD . Assuming the stud holes are 12mm the closest will be 20mm apart (centres) and the holes themselves 8mm . This should not be a problem for a steel hub I think . With the 4 stud rear disk type does the disk slide over the hub or bolt behind it ? Cheers A .
April 29, 200718 yr I drew up a "clocking" diagram and noted 100 and 140mm PCD . Assuming the stud holes are 12mm the closest will be 20mm apart (centres) and the holes themselves 8mm . This should not be a problem for a steel hub I think . With the 4 stud rear disk type does the disk slide over the hub or bolt behind it ? Cheers A . It bolts behind like the front hubs.
