Loyale Fuse Box
Anyone have a diagram telling me what each fuse is for?
For my 91 Subaru Loyale 4WD 5SPD manual.
I lost the cover for my fuse box. :clap:
Im trying to wire these LED lights to a switch, and then trying to figure out what fuse gets power all the time, etc.
Right...but I kinda need a quick answer. I just want to know all the fuses are for. There's gotta be a diagram some where. I found one, but it's not complete.
my image sucks forget it/CENTER]
See how it ends after it tells what the first 10 are...
Give me 5 Minutes and I will run out and take a pick of Buckys for you
THANK YOU SOOOOO MUCH BUCKY92
I LOVE USMB!!! :banana::banana::clap:
I LOVE USMB!!! :banana: :banana: :clap:
No Problem...this place helps me out enough..its the least I could do
Heh, well I still appreciate it :)
Too bad you're all the way in CT, or else I'd probably see you at the West Coast Subaru Show!
This place does rock but why can't I post pictures that big???:confused: :confused: :confused:
Are you using the WSIWYG editor? If so, just host the pictures somewhere else, then use "Insert Image" and put the link :-D
