?rocker arms?
I just pulled a motor for my 90 loyale, this donor motor had been in a wreck. The inner fender was pushed into the "valve cover" cracking it.
The wreck had also bent the right side cam gear. So, i pulled the cover and cam tower. All fo that for my question, do the flat spots on these rockers occur naturally or are they an evidence of tod being in the motor. I have searched and found nothing on the rockers. Should I look for rockers that are not flat spotted or run these?
thanks
ross
I think it's normal to see a slight lflat spot, but if it is Questionable I'd try to find some others. I've stripped down so many of these motors that I've got bins full of rockers and HLAs(lifters, but not)
