'00obw Posted December 2, 2003 Share Posted December 2, 2003 Hi. Plan to change the front (AT) and rear differential fluids myself and have a couple of questions. Front: I quess the fluid is removed thru the dipstick so what would I need to do that? Rear: What tool and size do I need to open the drain and filler plug? TIA...bg Link to comment Share on other sites More sharing options...
Setright Posted December 2, 2003 Share Posted December 2, 2003 Automatics have a separate compartment for the front diff. Both this and the rear diff probably use GL5 75W-90 oil - check the owners manual. ATF in the gearbox itself. Subes usually have drain plugs on all the transmission parts, but I can't be certain about yours... Rear diff plugs require a 1/2 inch socket driver. Link to comment Share on other sites More sharing options...
