August 12, 200718 yr I swear, if I find one more problem... Now I can feel a pretty strong vibration through the clutch pedal, directly related to RPM. It's as strong as an electric massager, but only when the clutch is engaged. I also have to push the clutch pedal almost all the way to the floor to get it to disengage. Before this happened there was about an inch of travel between the floor and the engage point. 98 Impreza L 2.2L 5MT. What do you guys think it might be? Think it might be related to that thunk I get when I push the clutch in too fast?
August 12, 200718 yr Author New news... It only vibrates when it's in gear, and I can feel it equally in the clutch AND brake pedal. :-\ Any ideas?
August 13, 200718 yr With vibes like that, I'd suspect that an engine mount or the transmission mount has bit the big one.
