August 10, 201015 yr Author car starts, revs up then dies after about 5 seconds. I can rev it fine but it will bog out and die. My other car did this and it was maf sensor. i swapped it for a different one and it still has the problem. Thoughts?
August 12, 201015 yr car starts, revs up then dies after about 5 seconds. I can rev it fine but it will bog out and die. My other car did this and it was maf sensor. i swapped it for a different one and it still has the problem. Thoughts? Dangit! Sounds exactly what mine is doing.
August 12, 201015 yr Author Dangit! Sounds exactly what mine is doing. and you solved it.....? how....? same boat eh? stupid cars...
