subaruguru Posted September 17, 2007 Share Posted September 17, 2007 ok so i havent tryed it yet but it should work its justa simple vacume. ok so you go to your local ranch and home or farm equiptment sales place and get a sirenge the things you use to give shots. get the bigger one it shouldent havea neadle on it. ok now take the seringe (idk how you spell it) and pull the plunger out of it take your lifter and put it in the tube then ad oil enough to cover lifter (have your finger over the little hole) then put the plunger in point the little hole up and push the air out, untel the fluid reaches the hole. then plug the hole and pull on the plunger this should pull the oil into the lifter. pullingthe air out. now in theory this should work just simple vacume. but i havent tryed it so if any one is doing lifters try this. and let me know i will be doing this next time i have to do lifters. Quote Link to comment Share on other sites More sharing options...
j2coe Posted September 17, 2007 Share Posted September 17, 2007 couldn't you just fill the syringe with oil and inject into the lifter like you would with a grease gun? Quote Link to comment Share on other sites More sharing options...
