Guest lesbaru Posted July 18, 2003 Share Posted July 18, 2003 Ok, I'm gonna take the plunge and.... CHANGE MY OWN OIL!!! (hey, it's a big deal for me ) Assuming I can manage it with the Haynes and Auto Repair for Dummies, what do I do with the used oil and filter afterwards? Link to comment Share on other sites More sharing options...
Guest PAezb Posted July 18, 2003 Share Posted July 18, 2003 Subies have to be one of the easiest autos to change oil and filter on. Where are you located on the planet? Many areas have recycling facilities, or any service station, are a couple of options for dropping off used oil and filters.... Paul Link to comment Share on other sites More sharing options...
Guest PAezb Posted July 18, 2003 Share Posted July 18, 2003 to add to my post above, just don't dump the old oil into the ground, sewer drain, etc, etc... but I'm sure you knew that. Paul Link to comment Share on other sites More sharing options...
Guest Flowmastered87GL Posted July 18, 2003 Share Posted July 18, 2003 At my parents house we leave the oil on the curb in a sealed clear gallon jug and the recycling people pick it up on garbage day. Check with your local trash collectors. Make sure to get a new crush washer for your drain plug then retorque to 30 ft. lbs. Link to comment Share on other sites More sharing options...
Guest GlCraigGT Posted July 18, 2003 Share Posted July 18, 2003 You should be able to take the used oil to a parts store where they will put the oil in a storage tank until a recycler comes and takes it away. Link to comment Share on other sites More sharing options...
Guest james hogan Posted July 19, 2003 Share Posted July 19, 2003 Some garages use a waste oil heater and would love to have your old oil. Jay Link to comment Share on other sites More sharing options...
Guest lesbaru Posted July 19, 2003 Share Posted July 19, 2003 Ok, I'll call around and see who takes oil here. How do I make the crush washer do 30 ft/lbs? Do I need to buy one of those torque-measuring wrench thingies, or can I fake it? My uncle said to buy one of the big plier style filter wrenches, so I'll be going on a tool shopping trip anyway. (my ex doesn't do his own car work so I can't borrow stuff from him) Hey, I like any excuse to go buy tools! Link to comment Share on other sites More sharing options...
Guest 99obw Posted July 19, 2003 Share Posted July 19, 2003 I think everyone should own a torque wrench. That way when you have tires mounted and the shop uses an impact wrench to tighten the lug nuts, you can loosen them and them torque them properly. BTDT. I really like the craftsman click type that I have. $60 if I remember correctly. Buy yourself a set of deep 1/2" drive metric sockets and a socket organizer while your at it. Hey, you said you like to buy tools. IMHO, if you need a filter wrench you are putting it on too tight. I don't even own one. If you do buy a filter wrench make sure that you still only install the filter hand tight. I usually go about 3/4 turn after the gasket touches. Be sure to fill the oil filter with oil before installing it. 99obw Link to comment Share on other sites More sharing options...
