November 3, 200718 yr Hello, new member here. This light went out recently but the digital display itself still works. You can see it in the daytime but at night it's hopeless. All other backlights work fine, including the digital odometer to the left. I'm assuming I can get a new light at the dealer or is the light integrated with the display unit itself? How difficult is this to access? Thanks for any help. I'd really like to fix this because this car has 110,000 miles and is otherwise in perfect condition. Little crap like this nags at me.
November 3, 200718 yr Welcome to the board! I haven't removed the cluster on our '01 but the previous years 95-99 are a piece of cake to remove. The bezel should have screws on the upper side underneath and on the inner bottom part. If you remove those it should pull off and be fairly easy to acess the rear of the cluster. Most likely you can find the bulbs at radio shack for cheap or at the dealer for a bit more.
