Minimum brake rotor thickness?
Guest applegump
What is the minimum brake rotor thickness on the Legacy? Are front and rear the same?
Thanks
'90 Legacy LS
Guest Tolerance02
Minimum rotor thickness for Legacy '90-'94.
Front;
for 13 inch wheels 16.00 mm. (standard (new) = 18.00 mm)
14 and 15 inch wheels 22.00 mm. (standard = 24.00 mm)
Rear;
massive rotor 8.50 mm. (standard = 10.00 mm)
ventilated rotor 16.00 mm. (standard = 18.00 mm)
1 mm. = 0.03937 inch.
1 inch = 25.4 mm.
Urban
Guest applegump
Looks like I need new rotors and pads in the rear and pads in front.
Thanks for the info Urban!
