November 19, 200718 yr I think I need to replace the radio antenna on my 91 Loyale. Has anyone done this? Is it a difficult job?
November 19, 200718 yr The hardest part about changing an antenna is when you have to route the new wire behind the dash, the mounting of the antenna wont be hard at all.
November 20, 200718 yr You have to remove the A pillar trim, unbolt the seatbelt track and let it hang, then undo the nuts that hold the antenna base. Remove the drivers side kick panel and the center console bucket that's in front of the shifter. You will see the connector for the antenna behind this bucket, on the drivers side underneath the ashtray area. Pull this apart. Strongly duct tape a sturdy piece of string to the loose end of the antenna lead. Pull it through under the carpet, it make take some hard jerks to get the tape that holds it to the floor pan to come loose. Once you have it all pulled out to the kick panel, pull it up the A-pillar and out the antenna hole. Use the string to pull the new antenna lead back through.
