March 27, 200818 yr I have a 90 legacy FWD and I really want to convert it to AWD or 4WD with the AWD conversion how possible is it to use parts from another 90 or equivalent and what it all takes now with the 4WD route I want to take the D/R from a GL and put that in what all would that take which one will produce a better vehical?
March 27, 200818 yr I'd recommend you look over my swap write-up www.surrealmirage.com/subaru/swap Parts from any of the 90-94 legacies and even some newer subarus can be used. The 4WD route would be more difficult as the engine/transmission mating points are different. If you search, you'll probably be able to find some more details on that. Josh
