April 6, 200818 yr Now that my 2000 OBW w/ 110K is back on the road with new MWE front axles, I still have a pronounced shudder on braking, easily felt through the steering wheel, and is at its worst when descending a grade while braking. Most likely causes? Tie rod ends? Inner or outer? Ball joints? Pads and rotors are fairly new.
April 6, 200818 yr the last time I had something like that it was a warped rotor. Do a "run out test" with a dial indicator and see how "true" they are (chill spots in the rotor will also give the same effect) another possibility is grease on the pads - even a little bit will cause "interesting things" to happen - particularly silicone grease because it doesn't burn off easily. And a bad wheel bearing will cause a similar effect as well. (assumed non-antilock system - otherwise if antilock - all of above possibilities plus tone ring issues or sensor problems) How does it react in hard braking?
