06 Frstr 45k what mtnce is due?
The gf's 06 frstr has 45k on it and has had regular oil changes, and tires. Last oil change the guys confused it with another car and flushed the ATF, we didn't pay for it. That's all thats been done. What's due?
Timing belts?
Head gaskets?
Rear diff?
Anything else to schedule in the next few months? Thanks, Matt.
Did you miss the 30 K service?
At 30K we do:
All FLUIDS except Brake and that wouldnt be a bad idea too.
Rotate and balance tires
Air filter
Fuel filter (dont think yours has one anymore)
plugs
Adjust belts if necessary
Lube hinges
Fuel treatment (We use BG 44K)
Battery service. Load Test, charge, and clean terminals and add battery pads.
You should consult your owners manual and do everything it says to do that you haven't already done in the maintenance schedule. If they did a flush they were supposed to use the SUPER type ATF and if they didn't you need to complain.
