bigjim5551212 Posted March 27, 2005 Share Posted March 27, 2005 The New Weber Carburetor will be available in about 60 days. It will be called the 34 DGEC. It will feature more tunability, namely changeable venturis. It will be 34 mm bore on both barrells. That is all I know. I would think it has the same bolt pattern as before. I hope it has jets that are easier to change. Quote Link to comment Share on other sites More sharing options...
pyromanic Posted November 19, 2005 Share Posted November 19, 2005 I found this old post and was wondering if anybody knows what happened with this "new" carb? The New Weber Carburetor will be available in about 60 days. It will be called the 34 DGEC. It will feature more tunability, namely changeable venturis. It will be 34 mm bore on both barrells. That is all I know. I would think it has the same bolt pattern as before. I hope it has jets that are easier to change. Quote Link to comment Share on other sites More sharing options...
bigjim5551212 Posted November 19, 2005 Author Share Posted November 19, 2005 I found this old post and was wondering if anybody knows what happened with this "new" carb? Yes, I know everything now. The original Webers are available and we have them in stock. The 34 DGEC is a Solex and I am not interested in those and neither should fellow Subaru enthusiasts. Call or email me if you need more info. Quote Link to comment Share on other sites More sharing options...
