1996 Legacy Brighton trailer wiring
3 replies to this topic
#1 jboymechanic
jboymechanic
    Subaru Fanatic!
  • 421 posts
  • Waterford, WI
Posted 28 September 2011 - 08:08 PM
Did the Legacy wagons have a trailer wiring harness plug-in from the factory? I can find the "no slice" direct plug in kits that "fit" 1996 Legacy Brightons, but I definitely cannot find the plug-in in the car. I'm assuming the manufacturers are incorrect or the factory wiring is only present on Outbacks?
#2 johnceggleston
johnceggleston
    Lite Master of the Subaru
  • 6,710 posts
  • Virginia
Posted 28 September 2011 - 08:16 PM
only on the outbacks from the factory.
#3 Scomber
Scomber
    New User
  • PipPip
  • 21 posts
  • Acadia
Posted 04 October 2011 - 01:28 PM
I just wired my 98 Brighton for a trailer. I built the trailer too.
The tricky thing is that most trailers are set up with one wire for tail lights, and one for turn signals on each side. Somehow, the brakes get worked in too.
In my case, without a bunch of diodes I didn't have handy, I had to wire for a flat 4 plug plus one separate wire. The separate wire does the tail lights. The flat 4 plug does left, right, and brakes.
If anyone else uses my trailer with a flat 4 plug, it will work. If I use another trailer with a flat 4 plug, it will work until I have to turn on the headlights, and then the trailer will stay dark.
Scomber Sanctus
#4 jboymechanic
jboymechanic
    Subaru Fanatic!
  • 421 posts
  • Waterford, WI
Posted 10 October 2011 - 02:53 PM
I ended up just cutting the plug off the trailer harness and wiring it up "the hard way". Works great and the wiring is just as clean.
