Brothers wagon
33 replies to this topic
#26 The Beast I Drive
The Beast I Drive
    CALL ME, (509) 391-5903
  • Gold Subscribers
  • 2,119 posts
  • Toppenish, WA
Posted 12 February 2013 - 03:46 PM
Sorry to hear about the strut top not fitting right, that's an issue I haven't run into yet. I'll keep tighter tolerances from now on.
-Bill
Edited by The Beast I Drive, 12 February 2013 - 03:46 PM.
#27 Mechanymous
Mechanymous
    New User
  • PipPip
  • 23 posts
  • Finland
Posted 13 February 2013 - 11:18 AM
Damn I love the look of that thing, I also have the same rims waiting for the lift so it´s nice to see how i´ts gonna look... someday =)
#28 AKghandi
AKghandi
    87 GL-10 2" lift 27" tires, 86 GL 2" lift 29"
  • 836 posts
  • Anchorage, Alaska
Posted 17 February 2013 - 01:03 AM
well I've been driving the snot out of the car, no problems real problems yet.
although one of the front cv boots tore, I have 2 brand new spares so I just gotta find the time to fix it.
In other news I cranked up the factory rear struts, and did more trimming in the front. only rub is at full lock now.
#29 AKghandi
AKghandi
  • 836 posts
  • Anchorage, Alaska
Posted 31 March 2013 - 12:20 AM
Took the car out wheeling this morning with 15+ built trucks, 2 of which were chevys on 44's the rest were jeeps, toyotas and range rovers.
Actually did pretty dang well, we weren't the first ones to get stuck! will have pics and video up soon.
learned a lot about what the car needs, so a new plan has been created. During some spirited attempts to get up a rather large hill, the car has started acting funny. it stalls and makes an almost knocking sound. due to the amount of work we were putting it through, and the fact it was overheating most of the time, I'm going to guess it cracked a head, no oil-coolant mixing yet.  The main problems I found was that I either had power, traction, or a clutch that was holding, never all three. Had to rev it to 6k and drop the clutch to get the tires going.
So plans will be as follows, along with the already planned welded rear, an SPFI block and heads will be purchased along with some delta TQ cams, and a webber. Going to build a high compression motor, with a full reseal. It will hopefully have enough power to get the tires going. This motor was already pretty tired so it should be a welcome increase in power. along with the motor a better clutch is needed, a local shop should be able to make me a nice heavy clutch for it, hopefully it will be near XT6 specs. Also going to work out some kind of snorkel.
Not sure when this will all be happening but it will be soon.
heres a pic, Not mine, one of the other wheelers. I will have my pics up soon.
Edited by AKghandi, 31 March 2013 - 12:49 AM.
#30 AKghandi
AKghandi
  • 836 posts
  • Anchorage, Alaska
Posted 31 March 2013 - 04:15 AM
#31 AKghandi
AKghandi
  • 836 posts
  • Anchorage, Alaska
Posted 01 April 2013 - 03:48 AM
#32 AKghandi
AKghandi
  • 836 posts
  • Anchorage, Alaska
Posted 22 April 2013 - 12:39 AM
 went out and got the car dirty yesterday
hows this for a view?
Edited by AKghandi, 22 April 2013 - 12:42 AM.
#33 AKghandi
AKghandi
  • 836 posts
  • Anchorage, Alaska
Posted 11 May 2013 - 06:15 AM
So did some more work to this beast today, I went wheeling in this little area near my house, and with everything melting there is some serious mud. I managed to find the deepest hole..Needless to say I got stuck up to the rockers, luckily a friend randomly happened to show up with impeccable timing, and pulled me out. then while keeping some speed up to make it through the mud, one of the sleeves on the rear adjustable struts slipped and left the tire touching the fender.
So then I went and bought the only 2 rear struts in town and replaced them, It doesn't sit as high as it used to but it rides a bit better. and it only took me 45 mins. Also If you don't have any new bumpstops to put in the struts, a couple old radius rod bushings work perfect.
I wish I had gotten some pictures of the stuck but I didn't have a camera.
soon after I got it fixed a guy's car broke down outside my house so I thought I would pay it forward and I towed him back to his house.
All in all a pretty eventful day.
#34 AKghandi
AKghandi
  • 836 posts
  • Anchorage, Alaska
Posted 17 May 2013 - 12:21 AM
more progress on the beast, replaced a couple vacuum lines and set the timing.
the timing was set at about 15 degrees, no wonder it was gutless and had ping under hard load. Set it to 8 degrees like is supposed to be and WOW what a difference, its like a different car. drove up a very steep snow bank, very short and very steep, the back bumper actually touched. drove up, came to a stop and it actually had enough power to keep climbing. Awesome.
