84 GL Turbo How to Fan Clutch
4 replies to this topic
#1 mgcwrnch
mgcwrnch
    Member
  • PipPip
  • 18 posts
  • chico, california
Posted 08 April 2013 - 11:32 AM
Fan Clutch seems to be shot.  How do the four bolts to the water pump come out  ??   No room to get wrench at them.
Remove radiator, alternator, take out engine  ??
Bruised hands need to know  !!
#2 mikaleda
mikaleda
    legacy specialtist
  • 2,263 posts
  • priest lake, Idaho
Posted 08 April 2013 - 11:53 AM
Removing the rad would probably help a lot, try that first and go from there.
#3 91_EJ_22
91_EJ_22
    New User
  • PipPipPip
  • 76 posts
  • lakewood, wa
Posted 08 April 2013 - 12:17 PM
yeah we can normaly get it done by pulling the rad and then you can put on two electric fans if you want
Edited by 91_EJ_22, 08 April 2013 - 12:18 PM.
#4 man on the moon
man on the moon
    Subaru Fanatic!
  • 609 posts
  • Denver
Posted 08 April 2013 - 02:04 PM
I use a pair of long handled pipe wrench or channel locks to hold the shaft of the fan, and a 10m box end wrench to work the nuts loose. Remove the four at the back of the fan, not the ones buried in the fins the front. A 22m box end will also hold the fan shaft, just make sure to grab the flattened sections and not the rounded parts of the shaft!
#5 man on the moon
man on the moon
    Subaru Fanatic!
  • 609 posts
  • Denver
Posted 08 April 2013 - 02:06 PM
It also helps if you remove the fan shroud.
