Need head swap input/advice. 2,5 DOHC to 2.5 SOHC.
6 replies to this topic
#1 Dakotademon7
Dakotademon7
    Advanced Member
  • PipPipPip
  • 32 posts
  • Smyrna Delaware
Posted 01 November 2013 - 09:25 PM
I have a 98 Outback with a 2.5 DOHC. There is a 2000 Legacy at my work with a 2.5 SOBC dual port. I'm interested in installing the single cam heads on my 2.5 DOHC block. I tried to search but didn't find any helpful info.
#2 Fairtax4me
Fairtax4me
    Sooberoo
  • 12,971 posts
  • Charlottesburg, VA
Posted 01 November 2013 - 11:47 PM
Won't be able to make that swap work. Not easily at least. That SOHC engine has too many differences in electronics. You would need heads intake manifold, and the whole wiring harness and ECU to go with it.
Much easier to find a 95 dual port 2.2 and put those heads on the 2.5 block. Still need the manifold to go with the heads, but the electronics are identical to your 98, so you just plug the manifold harness into your existing ECU and go.
This swap will raise your compression and require you to run premium fuel though.
#3 Dakotademon7
Dakotademon7
    Advanced Member
  • PipPipPip
  • 32 posts
  • Smyrna Delaware
Posted 02 November 2013 - 09:35 AM
So your saying my DOHC intake won't fit the SOHC heads and that's the need for the harness change.?
#4 Fairtax4me
Fairtax4me
    Sooberoo
  • 12,971 posts
Posted 02 November 2013 - 09:57 AM
Correct.
#5 Bushwick
Bushwick
    1000+ Super USER!
  • 1,352 posts
  • Ohio Akronish
Posted 02 November 2013 - 10:10 AM
Are the exhaust manifolds the same for a dual port head?
#6 Gloyale
Gloyale
    It's a sickness
  • 10,631 posts
  • Corvallis, OR PNW
Posted 02 November 2013 - 10:16 AM
Yes all EJ dual port exhaust will interchange.
#7 Dakotademon7
Dakotademon7
    Advanced Member
  • PipPipPip
  • 32 posts
  • Smyrna Delaware
Posted 02 November 2013 - 10:44 AM
On to plan B. There's a 97? Outback sport at my work with the 2.2 and manual trans in it. It would be nice to install that.
