Composite HG with frankemotor (ej22e heads, ej25d block
8 replies to this topic
#1 MilesFox
MilesFox
    Catch this Fox!
  • 10,686 posts
  • Madison/Milwaukee, WI
Posted 09 November 2013 - 10:54 PM
So i have a forester engine for the ej25d block, and just got a set of phase 1 first gen legacy ej22e heads, dual ports. I also got a set of ej22e composite HG's.
I have alredy done a frankenmotor using he cometic hybrid MLS gaskets. Considering i have all the parts, but don't have the 200 bucks for cometics, soes anyone see a problem withusing the composite head gaskets on the ej25d block. I will be using the ej22e heads with their original head bolts. And i will also have to port match the water jacket.
Pros and cons? Opinions? (have i asked this before?
MY car has some farmer built straight pipe and won't pass emissions, and i have a catte mid pipe to use(with dual port header), but the engine in my car is single ports, and i could put a dual port engine together to swap in sooner than i can find a single port header.
Edited by MilesFox, 09 November 2013 - 10:55 PM.
#2 darsdoug
darsdoug
    USMB Regular
  • 373 posts
  • Seattle
Posted 09 November 2013 - 11:29 PM
I think you should try them regardless of my own selfish curiosity whether or not the higher compression will cause them to fail?
#3 MilesFox
MilesFox
    Catch this Fox!
  • 10,686 posts
Posted 09 November 2013 - 11:34 PM
I would try this for my own curiosity. You are welcome to the results if (when) i do.
I fi remember right, the rule to apply is use the gasket that goes to the head. I can see where this gets confused using MLS with phase 2 engines. Both the ej25d and the ej22e are open deck blocks. Now, do the phase 1 dohc engines in the overseas markets WRC era 90-95 use composite or MLS?
Edited by MilesFox, 09 November 2013 - 11:35 PM.
#4 MilesFox
MilesFox
    Catch this Fox!
  • 10,686 posts
Posted 09 November 2013 - 11:36 PM
Also, I am supporting the idea of composite gasket considering the head bolts on ej22e are external allowing for re-torque without removing cams or valve covers.
#5 Gloyale
Gloyale
    It's a sickness
  • 10,933 posts
  • Corvallis, OR PNW
Posted 10 November 2013 - 02:08 PM
NO you need a gasket for the block.  The fire ring on the 2.2 gasket will be too small for the larger 2.5 bore.
That's the problem....you need a gasket with water ports that match a 2.2 head, and a bore size to match the 2.5 block.
Or drill the gasket to match the 2.2 heads
#6 MilesFox
MilesFox
    Catch this Fox!
  • 10,686 posts
Posted 10 November 2013 - 03:25 PM
Ok, i see now. I failed to take that into consideration. Gasket matches the block, then. Too bad there isn't an aftermarket composite 2.5 gasket.
#7 MilesFox
MilesFox
    Catch this Fox!
  • 10,686 posts
Posted 10 November 2013 - 09:55 PM
I found an article pertaining to subaru HG failures, and in the article it states that the 1996 ej25d used the composite HG before switching to MLS in 97.
http://allwheeldrive...lems-explained/
#8 Caboobaroo
Caboobaroo
    USMB Drunk
  • 7,157 posts
  • Oregon City
Posted 12 November 2013 - 11:42 PM
Yes, the '96 2.5 had a composite head gasket.
#9 Jerry DeMoss
Jerry DeMoss
    Pushrods 'O' Fury
  • 2,408 posts
  • Colorado
Posted 13 November 2013 - 12:04 AM
Just use '05 mls sti headgaskets. Works great with the ej22 heads on a ej25 block. No complaints from any of these I have done.
