1-3-2-4 Posted April 4, 2014 Share Posted April 4, 2014 I get codes p0507 and p1507 cleaned IAC and may.. Testing tps pins 1 & 2 I get 5 v idle and 1.0v wot Quote Link to comment Share on other sites More sharing options...
1-3-2-4 Posted April 4, 2014 Author Share Posted April 4, 2014 Also the car is a 99 legacy sus with a auto.. Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted April 5, 2014 Share Posted April 5, 2014 DOHC 2.5 engine? TPS should have: Red : ECU ground White : Signal voltage Black : Reference, 5V The only one you need to really be concerned with is the white wire. Check for 0.5v with key On, engine Off, throttle closed. 4.5v at wide open. Ground the meter to engine ground or battery -. You're checking voltage difference between the pins. That doesn't directly tell you what you need to know, though if those numbers are correct, it means the TPS is out of adjustment. Quote Link to comment Share on other sites More sharing options...
1-3-2-4 Posted April 5, 2014 Author Share Posted April 5, 2014 It's a SUS so it's a 2.5 DOHC. And yes before the battery on my phone died I noticed I was checking the wrong wires so the TPS is fine.. the IAC on the other hand I don't know.. the friken PCV hose that leads to the block was fully blocked.. I had to clean that out plus drive 40 miles to get the a replacement PCV hose connector because it snapped on the first pull of a hose.. Anyways, I did not fully take off the IACV because of the gasket issue so I just did the front side of it.. I do have a spare one from a EJ22.. what I used to clean it was throttle body cleaner which is what I had on hand. Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted April 5, 2014 Share Posted April 5, 2014 Broken PCV hoses means other broken hoses as well. Did you replace the PCV valve? Codes make me think vacuum leak, or the throttle body is caked up with carbon sludge and really needs a cleaning. Seafoam it! If nothing else, its fun! Quote Link to comment Share on other sites More sharing options...
