machthree2 Posted July 7, 2014 Share Posted July 7, 2014 Went to salvage and got both rails and guy said these should fit. injectors that is Jethro. Well the O rings on bottom are slightly tighter on ID and not as fat as the 90 injector. The rails are mounted different too, so had to switch 98 injector to original rail. seems ok but idle is a little rough. the newer injectors have a cone on bottom and look a little improved. will put the others in this week and report back. i put the 90 lower O rings on this second set because of Rail fit. hope they work. otherwise, the car is running beautiful, and really has awesome power and as fun to drive as my old MG's Quote Link to comment Share on other sites More sharing options...
machthree2 Posted July 8, 2014 Author Share Posted July 8, 2014 Went to salvage and got both rails and guy said these should fit. injectors that is Jethro. Well the O rings on bottom are slightly tighter on ID and not as fat as the 90 injector. The rails are mounted different too, so had to switch 98 injector to original rail. seems ok but idle is a little rough. the newer injectors have a cone on bottom and look a little improved. will put the others in this week and report back. i put the 90 lower O rings on this second set because of Rail fit. hope they work. otherwise, the car is running beautiful, and really has awesome power and as fun to drive as my old MG's replaced 2 nd rail with 2 98 injectors and no change to system. just wanted consistency.the injectors went in tight (good) and i think the O rings will work. . One last problem is that it seams to run cold when started, and i need to check the "cranking voltage from starter again" Otherwise, off to the races. Quote Link to comment Share on other sites More sharing options...
presslab Posted July 9, 2014 Share Posted July 9, 2014 Is your '90 motor from an auto or manual trans? If I recall those had either white top or gray top injector depending on trans... The red top were used from '92- and are pretty close in flow to the ones you have. You could also put a '92 ECU in there, it's a different design internally but will plug in and will match the red tops. Quote Link to comment Share on other sites More sharing options...
Hsoj Posted July 9, 2014 Share Posted July 9, 2014 I got codes thrown from having the wrong injectors in my 90 lego auto I used for a swap. I had no luck with swapping in a 92 ecu either, it wouldnt run. Quote Link to comment Share on other sites More sharing options...
86BRATMAN Posted July 9, 2014 Share Posted July 9, 2014 The 92 ecu also needs the plastic maf, and if it's a manual you have to swap the iacv as well. Quote Link to comment Share on other sites More sharing options...
machthree2 Posted July 10, 2014 Author Share Posted July 10, 2014 so i am little confused. the donor car was a 90 legacy with a newer motor? it had the red top injectors in it so it may be newer. the injectors i put in have a conical tip where the ones removed where shorter and more open. when starting cold the rpm's are down at 400 and hard keep running. Once warm, at 900 it runs fine. I'm going try going back to the original type injectors as a test. Quote Link to comment Share on other sites More sharing options...
