1998 Outback Lift - Help me get get my facts straight?
10 replies to this topic
#1 Dirty Dan
Dirty Dan
    Newbie
  • Pip
  • 6 posts
  • Chelsea, Michigan
Posted 14 July 2014 - 07:17 PM
Planning a lift for my 1998 Outback, just wanted to run it by you guys and see if it sounds reasonable.
-Forester Struts
-Forester Tophats
-Forester Iron Man springs (Subtle Solutions)
-Forester 1" lift / strut spacers (Subtle Solutions)
-Adjustable rear trailing arms (Gorilla Off-road Company)
-215/75-15 All terrains or mud terrains, haven't decided.
I guess what I'm wondering is whether or not I'll be able to get this tall without any other modifications, if this wasn't my daily I wouldn't mind cutting and fabbing parts, but since it is I'd prefer this to be an entirely bolt on and go type of deal. Too much lift with the forester struts, lift springs, AND spacers? Or do you think it'll be reasonable. I expect a bit more CV wear I just don't want anything obscene.
Also, think that tire size is good or would I be able to go bigger?
Thanks in advance guys, I'm excited to get this going.
#2 Crawlerdan
Crawlerdan
    Eat, Live, Breath Subaru
  • 489 posts
  • montana
Posted 14 July 2014 - 09:10 PM
i personally went 2.5 over stock with my 99. i used a 225 70 16
many many miles, mo issues with oem cv's. rump roast-loads of ground clearance, rode like stock
i used a 2 inch spacer and h6 springs
nothing else required. it was jumped, wheeled hunted out of, used like no other
#3 Dirty Dan
Dirty Dan
    Newbie
  • Pip
  • 6 posts
  • Chelsea, Michigan
Posted 14 July 2014 - 09:18 PM
So somewhat similar to what I've planned height wise? I Figure an inch or so with the forester struts, another inch with the springs, then another inch with the spacers. So around 3" or a little less I imagine?
Edited by Dirty Dan, 14 July 2014 - 09:22 PM.
#4 Crawlerdan
Crawlerdan
  • 489 posts
  • montana
Posted 14 July 2014 - 09:20 PM
ya, sounds close. your front sway bar end links will be pissed. a good front axle wont have issues. have fun with it
#5 Dirty Dan
Dirty Dan
    Newbie
  • Pip
  • 6 posts
  • Chelsea, Michigan
Posted 14 July 2014 - 09:25 PM
Right on, I'm pumped!
Any fixes for the end links? I hadn't even thought about that. May just ditch the rear bar but I sort of wanted to keep the front since it's a daily driver.
#6 Crawlerdan
Crawlerdan
  • 489 posts
  • montana
Posted 14 July 2014 - 09:26 PM
yep- you can use machined aluminum endlinks for a wrx or sti
#7 Dirty Dan
Dirty Dan
    Newbie
  • Pip
  • 6 posts
  • Chelsea, Michigan
Posted 14 July 2014 - 09:34 PM
Perfect, thanks for the help!
I've seen that there are sedan and wagon end links. Assuming I end up keeping the rear bar, would I want to go with the sedan or wagon links? I'd assume wagon, but you know what they say about assuming...
#8 Crawlerdan
Crawlerdan
  • 489 posts
  • montana
Posted 14 July 2014 - 09:35 PM
i dont know that there is a difference , but i am retarded......so.....
#9 Dirty Dan
Dirty Dan
    Newbie
  • Pip
  • 6 posts
  • Chelsea, Michigan
Posted 14 July 2014 - 09:39 PM
Hahahaha, fair enough man. Like I said, I'll probably lose the rear bar anyway. Even if I don't, I imagine the fronts would be more important anyways and it looks like there's plenty of choices for just a set of fronts that don't come with the rears.
#10 Dirty Dan
Dirty Dan
    Newbie
  • Pip
  • 6 posts
  • Chelsea, Michigan
Posted 15 July 2014 - 07:10 AM
You have any pictures of your 99 floating around?
#11 Crawlerdan
Crawlerdan
  • 489 posts
  • montana
Posted 15 July 2014 - 08:01 AM
No I sold it to my nephew
