Automatic Trans Interchange
3 replies to this topic
#1 Phillip
Phillip
    USMB is life!
  • 167 posts
  • Eugene, OR
Posted 28 May 2004 - 08:50 PM
The transmission in my '99 Outback Legacy Wagon is starting to slip on the 2-3 upshift and I need to replace it. Does anyone know the years/models that will interchange? Thanks in advance!
#2 Legacy777
Legacy777
    Moderator
  • Moderator
  • 12,810 posts
  • Houston, Tx
Posted 31 May 2004 - 02:45 PM
you might be able to adjust the brake band. Have you changed the fluid recently? How many miles?
#3 mudrat79
mudrat79
    Banned
  • Banned
  • 697 posts
  • Eugene,
Posted 01 June 2004 - 09:17 AM
If You must change, I know from personal Swapping , that all Were Basically the same from 90-00 ....Only diff was in Speed-O Cable Hook-up......
On 90-92 it has a Mechanical Speed-O, on 92 and Newer they went to Electronic Pick-up.....Both Units Bolted into the same spot on the tranny....
All electrical conections were the same.....A few wires changed color, but perform same function......
I Stuck a 70,000 mile 97 trans into a 90 Sedan, with no issues
Hope this helps, John in Oregon.....
#4 Phillip
Phillip
    USMB is life!
  • 167 posts
  • Eugene, OR
Posted 01 June 2004 - 05:58 PM
Thanks for the replies. I manage a large fleet of vehicles and deal with a very sharp local trans shop (Transmission Solutions in Eugene OR) who put his finger on the problem immediately. It's going in to the shop next Monday for $1400 worth of trans work! I must say that I haven't been all that impressed with the reliablity of Subaru's. At 91,000 miles I replaced the engine (spun two rod bearings) and now at 98,000 it's ready for major transmission work. My wife really loves her '99 Outback; too bad for me. Thanks again for your help.
