Front accy pulley on 95 Outback. (2.5l)
2 replies to this topic
#1 c150L
    Subaru Nut
  • 532 posts
  • East Central Wisconsin
Posted 12 September 2004 - 09:22 PM
I'm looking for the accy pully for a 95 Outback with 2.5L engine. (Pulley and bolt) Anyone have one laying around? Would the one fit off the front of my 89 XT6? (Before it goes to the junk yard?) I need to fix a friends Outback.
Is that common for the pulley to strip like that? Oddly enough, I saw 2 yesterday. This Outback and a 91 Impresa at an auction. Both had the front engine pullies off and key had stripped the hole in the pully identically. (Vehicals from totally different parts of the country.)
#2 DerFahrer
    Formerly subyluvr2212
  • 2,420 posts
  • Orlando, FL
Posted 12 September 2004 - 09:56 PM
It happens all the time. Us 90-94 Legacy guys have horror stories long as your arm...
The problem is that people don't torque down the bolt enough. The Subaru manual calls for 80 ft-lbs I think, but it should really be 110 ft-lbs! :eek: After doing my timing belt, I heard some stories and actually went back and tightened my bolt down even harder, because I'd like to keep my crank from being torn to pieces, thank you very much :)
I'm sorry though, the pulley from your XT6 won't work. The pulley on EA-series engines doesn't touch the key, it only has a little ridge that holds onto the timing belt sprocket.
You might wanna ask in the Marketplace to see if anyone has a spare pulley... Also, try this place for used Subaru parts. www.4subarusuzukikiaparts.com
#3 c150L
    Subaru Nut
  • 532 posts
Posted 13 September 2004 - 11:31 PM
Thank you for the info. As for the EA engines pully, that would explain one of my last EA82 timing belt capers where I did not remember finding a key connection to the pulley.
