Tinkerers Posted November 25, 2004 Share Posted November 25, 2004 Ok, what could be causing oil leaks in a 2000 Outback with 113,000 miles ? The car has always been a little leaky, but seems worse lately. Underneath, everything is covered with oil, can't tell where leak is. Thanks, Paul Quote Link to comment Share on other sites More sharing options...
frag Posted November 25, 2004 Share Posted November 25, 2004 That's on almost every top of the line Subarus: undercarriage automatic rust treatment. Quote Link to comment Share on other sites More sharing options...
Setright Posted November 25, 2004 Share Posted November 25, 2004 LOL frag! On a serious note: The cam, crankshaft, oil pump, and rocker cover seals are all prone to leaks. Replace them along with the timing belt. Quote Link to comment Share on other sites More sharing options...
pollyavis Posted November 25, 2004 Share Posted November 25, 2004 Ok, First Degrease The Entire Engine Real Well And Then Run The Engine Until Up To Temp , Get A Good Light And With The Car Safley Raised Start Looking For The Leak Probably Wont Take Long To Find It. I Dont Like To Pay For Gaskets Or Seals That Aren't Needed. Good Luck. Quote Link to comment Share on other sites More sharing options...
cookie Posted November 26, 2004 Share Posted November 26, 2004 seals. I had them all changed on my Subaru and it does not leak at all. I don't recall any vehicle I have owned so prone to seal failure as a Subaru. both my BMW and my Subaru are 99s. The BMW has had no seals changed and does not leak at all. The Subie required all of them. Quote Link to comment Share on other sites More sharing options...
Setright Posted November 26, 2004 Share Posted November 26, 2004 Oh yeah, a new PCV valve would also be good idea, keeps the crankcase pressure down, and hence the oil has less incentive to seep out. Quote Link to comment Share on other sites More sharing options...
Tinkerers Posted November 26, 2004 Author Share Posted November 26, 2004 Looks like I need to replace some or all of those leaky oil seals. Is there a web site that might offer instructions on how to replace this stuff? Thanks, Paul Quote Link to comment Share on other sites More sharing options...
cookie Posted November 26, 2004 Share Posted November 26, 2004 for mechanics who work on Subies. I am sure some of the other folks will give you several more.I think Josh has a lot of info on his site and he is one of the moderators here. Do a search on changing cam belts or cam seals or oil pump seals and you should find a lot of info. Quote Link to comment Share on other sites More sharing options...
