coolant temperature sensor
3 replies to this topic
#1 96legacy
96legacy
    New User
  • Pip
  • 2 posts
  • Waco
Posted 25 January 2005 - 02:04 PM
My check engine light came on and a scan revealed a bad coolant temperature sensor. How hard could that be to replace, right? Where is the blasted thing located on my 96 Legacy Outback with a 2.2, 5 speed? I'm kind of new at this, so thanks for your help.
#2 1990legacy
1990legacy
    USMB Regular
  • PipPipPip
  • 74 posts
  • Harrisonburg
Posted 25 January 2005 - 02:10 PM
Well, I just did the one on my car, and since it would appear you have the same engine, the temp sensor on your car should be located below and to the left of your alternator, which has to come out to get at the sensor. But really, its a fairly simple task, just remember the order in which you took things out. And the sensor should run you like $7 or so at a parts store.
#3 Bill90Loyale
Bill90Loyale
    Subaru Fanatic!
  • 423 posts
Posted 25 January 2005 - 02:11 PM
The sensor is to the left of the coil pack and tucked way down underneath some PCV hoses and two big wiring harnesses. Hard to find the first time. Search the forum. There are pictures out there. A bad CTS should cause you to be having hard starting (turns over, but won't fire up the way it should). About $30.
#4 96legacy
96legacy
    New User
  • Pip
  • 2 posts
  • Waco
Posted 26 January 2005 - 06:45 PM
Thanks for your help. I found it, replaced it and voila! No light.
