Subaru recommended timing belt replacement
105,000 is the recommended service interval - I've yet to see one on the later model engines break. If you stick to the manufacturer's recommended service intervals, you'll be fine.
Subaru recommends changing your timing belt every 105,000 miles on a 2000 or newer model. Do you think this is right or should it be done more often? Will it destroy the engine on a 2000 legacy if the belt does break? I found that service interval here:
http://www.cars101.com/subaru/subaru_maintenance.html
Ben
