pcpracing Posted February 27, 2005 Share Posted February 27, 2005 ok, we just replaced the head gaskets and put it all back together. every thing is cool and runs great but the running lights keep blinking. whats up with this? The car is a 97 outback 5 speed. we think that it has remote locks, but it was used so we don't have the key fobb for it. if any one knows what it could be, Please let me know.! Quote Link to comment Share on other sites More sharing options...
bearbalu Posted February 27, 2005 Share Posted February 27, 2005 I read somewhere on this forum - do searches - that if you disconnect negative, put key in ignition at on positoon and connect it back with key in ignition it might work. Quote Link to comment Share on other sites More sharing options...
Cliptin Posted February 27, 2005 Share Posted February 27, 2005 I believe there is a button on top of or around the steering column that causes this. Quote Link to comment Share on other sites More sharing options...
brus brother Posted February 27, 2005 Share Posted February 27, 2005 http://www.cars101.com/subaru/keyless.html#05%20legacy%20program%20remotes Check out he above link for info regarding disarming alarm. Also, I have read about "disconnect negative, key on position, reconnect negative terminal" and it seems like a cheap and easy fix if it works. Quote Link to comment Share on other sites More sharing options...
FSRBIKER Posted February 27, 2005 Share Posted February 27, 2005 Turn the key on and hold in the alarm programming button for a few seconds and it will stop. The button is on the drivers side under the dash by your left foot, right near the kick panel. It might take a few minutes to find it, mine is ziptied to a bunch of other wires. Quote Link to comment Share on other sites More sharing options...
pcpracing Posted March 1, 2005 Author Share Posted March 1, 2005 Turn the key on and hold in the alarm programming button for a few seconds and it will stop. The button is on the drivers side under the dash by your left foot, right near the kick panel. It might take a few minutes to find it, mine is ziptied to a bunch of other wires. thanks alot FSRBIKER. thats what it was. hit that button and it stoped flashing!!! it was under the alarm control box zip tied to a holelota other wires, had to cut the control box from the kick panel to get to it. Quote Link to comment Share on other sites More sharing options...
