gasket list
2 replies to this topic
#1 oddcomp
oddcomp
    Subaru Master
  • 1,763 posts
  • longview ,wa
Posted 30 August 2003 - 05:10 PM
i need to change what appears to be a water leak between the head and the drivers side intake manifold on a 86 rx ea82t
what gaskets will i need besides the left and right intake manifold gaskets?
#2 oddcomp
oddcomp
    Subaru Master
  • 1,763 posts
  • longview ,wa
Posted 31 August 2003 - 10:17 PM
#3 GLCraig
GLCraig
    Frak
  • 2,706 posts
  • Canby @#$% Oregon
Posted 31 August 2003 - 11:02 PM
It depends. On some or all of the turbos (can't remember which) the water tubes that run to the thermostat, unbolt form the rest of the manifold. If it's leaking where these tubes bolt up then you'll need the gaskets for the tubes and the ones for where the manifold bolts to the head. Also since you're going to be taking off the manifold you might as well replace all of those little water hoses while you're at it.
