Plug & Wire Upgrades. Thoughts?
9 replies to this topic
#1 ScoobySchmitty
ScoobySchmitty
    I am The Stig.
  • 475 posts
  • Kalamazoo
Posted 03 September 2003 - 06:52 PM
I'd like to install new wires and plugs in my 91 Legacy for better mileage and/or acceleration (when I need it), but a few questions....[list=1]
[*]What brand wires & plugs should I use?
[*]What kind of gain should I expect, such as high-rpm or low-rpm increase in HP?
[*]What about a new coil-pack? Do they even MAKE performance coil packs?
[/list=1]
Thanks for the help guys & gals!
ScoobySchmitty:burnout:
#2 Legacy777
Legacy777
    Moderator
  • Moderator
  • 12,809 posts
  • Houston, Tx
Posted 03 September 2003 - 07:19 PM
ngk coppers & magencor.
Don't expect to see any real improvements in power with just plugs and wires. Car may run a little smoother.....but like I said, don't expect to see 5 hp.
#3 ScoobySchmitty
ScoobySchmitty
    I am The Stig.
  • 475 posts
  • Kalamazoo
Posted 03 September 2003 - 07:24 PM
Yeah, I know that whole Splitfire =5 hp boost is BS, I just didn't know if the wires would make a difference. I've got NGK V-Power plugs in right now, don't know the wires, but it runs well. What other engine mods would be do-able, besides a cold air intake (DONE :brow: )
ScoobySchmitty
#4 Rice Burner
Rice Burner
    USMB Regular
  • PipPipPip
  • 41 posts
  • morgantown, wv
Posted 03 September 2003 - 09:26 PM
I just installed NGK iridium plugs and premium wires from NAPA. they seem to work fine.
#5 sprintman
sprintman
    USMB Regular
  • PipPipPip
  • 105 posts
  • Canberra Australia
Posted 04 September 2003 - 08:57 PM
NGK Iridiums for mine!
#6 Setright
Setright
    Elite Master of the Subaru
  • 3,176 posts
  • Denmark
Posted 05 September 2003 - 04:24 AM
Been through a number of different brands and models. I have settled on Bosch FR7Dx. FR78x "Super 4" don't agree with the DIS.
Cables are OE, but only two years old.
Cold air intake? Surely the car had this already? Legacies I and II suck air from the right fender. I trust you mean that you have removed the "intake resonator"??
http://www.geocities...ube/intake1.jpg
#7 ScoobySchmitty
ScoobySchmitty
    I am The Stig.
  • 475 posts
  • Kalamazoo
Posted 06 September 2003 - 09:29 AM
In a matter of speaking, I removed the filter box and replaced it with a Cosmo Racing cone filter. A lot of cars do not follow the "cold air" idea because they worry about mainfold icing, so the pre-heat the intake air. :madder: Stupid idea. You get more power from MORE DENSE cold air! Anyway, it's just a bigger intake than that little hole on my filter box. Legacy777 had said he made more intake holes on the bottom of his airbox, and this worked out as well as a washable filter. Guess I should have read this before spending the $30 on the new filter :-P Oh well, it looks better than the filter box did :brow:
ScoobySchmitty:banana:
#8 Subie Gal
Subie Gal
    GC84Ever
  • 1,450 posts
  • WA
Posted 13 September 2003 - 10:30 PM
as was said
there are no real gains to "upgrading" plugs and wires on your OE car.
if you have the OE engine... what is the point?
you wont see any gains.
save the $$ and put it elsewhere....
bet OE plugs/wires which were DESIGNED for your car
and make the car run RIGHT.
NO hiccips
NO hesistation issues
(these can be found with the inappropriate plugs/wires)
most discount subie stores offer these things cheap!!!
(ours is 30% off retail!!) that's the route i'm going...
and that's my $.02 and change :D
cheers
Jamie
#9 ScoobySchmitty
ScoobySchmitty
    I am The Stig.
  • 475 posts
  • Kalamazoo
Posted 14 September 2003 - 08:18 AM
Like in the top of the post, I just wanted to get a general concencus on getting new types of plugs/wires. The stock plugs and wires ARE doing a good job right now. Thanks for all the input everybody, this really helps out!
ScoobySchmitty
:headbang:
#10 sam45
sam45
    New User
  • PipPip
  • 21 posts
  • New Jersey
Posted 14 September 2003 - 10:14 AM
Is there a difference between Subaru OEM wires and the wires you can order directly from NGK? Does NGK make wires for Subaru? It looks like the OEMs from the dealer cost much less than the NGK when you order directly from NGK. I checked couple of dealers in our area and they are charging exactly the same....
