benking Posted May 13, 2005 Share Posted May 13, 2005 I am getting a front end noise when starting from a dead stop at a light or stop sign. It seems to only be happening when the cars wheels are pointed straight. The noise is getting slightly worse as time goes on. It sounds like 2 things rubbing or a part very worn down. I was wondering if it could be shocks, but i think it is something in the steering or tie end rods. Any help would be appreciated. Thanks Ben Quote Link to comment Share on other sites More sharing options...
benking Posted May 13, 2005 Author Share Posted May 13, 2005 I am getting a front end noise when starting from a dead stop at a light or stop sign. It seems to only be happening when the cars wheels are pointed straight. The noise is getting slightly worse as time goes on. It sounds like 2 things rubbing or a part very worn down. I was wondering if it could be shocks, but i think it is something in the steering or tie end rods. Any help would be appreciated. Thanks Ben It actually only seems to be when I am making left turns. When making right turn I hear no sound. Ben Quote Link to comment Share on other sites More sharing options...
zooma37 Posted May 13, 2005 Share Posted May 13, 2005 It actually only seems to be when I am making left turns. When making right turn I hear no sound. Ben Ben, I have encountered exactly the same problem on my 03 Forester, but I can't figure the problem out. The noise occurs only on tight left turns, not right. Quote Link to comment Share on other sites More sharing options...
Setright Posted May 13, 2005 Share Posted May 13, 2005 benking, we need some info about your car please. Offhand, I would say it's a CV joint. Quote Link to comment Share on other sites More sharing options...
zooma37 Posted May 13, 2005 Share Posted May 13, 2005 benking, we need some info about your car please. Offhand, I would say it's a CV joint. My car's been making that noise almost since I bought it two years ago. If it's a CV joint, how expensive is the repair? Quote Link to comment Share on other sites More sharing options...
ofairlane Posted May 13, 2005 Share Posted May 13, 2005 you should provide more info on the noise, cv joints usually make a clicking or a clunking noise when turning. is the noise on the left, right, middle of the car? does it make the noise while driving, when accelerating, when accelerating from a stop. info like this would help us help you more. update us on this, DanO Quote Link to comment Share on other sites More sharing options...
zooma37 Posted May 13, 2005 Share Posted May 13, 2005 you should provide more info on the noise, cv joints usually make a clicking or a clunking noise when turning. is the noise on the left, right, middle of the car? does it make the noise while driving, when accelerating, when accelerating from a stop. info like this would help us help you more. update us on this, DanO The noise sounds like to pieces of metal rubbing together and it only occurs on sharp/tight, low-speed turns to the left - when I am pulling into my garage. The noise doesn't occur on right turns or driving straight or at faster speeds. I thought maybe the backing plate would be the problem, but not sure. MD Quote Link to comment Share on other sites More sharing options...
Setright Posted May 14, 2005 Share Posted May 14, 2005 Ok, I would suggest brake rubbbing or wheel bearing failure. Quote Link to comment Share on other sites More sharing options...
zooma37 Posted May 14, 2005 Share Posted May 14, 2005 Ok, I would suggest brake rubbbing or wheel bearing failure.[/quote Thanks for your help, Setright. What does brake rubbing mean? Also, the car has been making the noise since I bought it two years ago, and the dealer tells me there's nothing wrong, but I still hear the noise. Are wheel bearings expensive to replace? Quote Link to comment Share on other sites More sharing options...
zooma37 Posted May 14, 2005 Share Posted May 14, 2005 I almost forgot one thing - the noise seems worse when the wheel is wet. Any ideas. Quote Link to comment Share on other sites More sharing options...
turbo92subaru Posted May 14, 2005 Share Posted May 14, 2005 I am getting a front end noise when starting from a dead stop at a light or stop sign. It seems to only be happening when the cars wheels are pointed straight. The noise is getting slightly worse as time goes on. It sounds like 2 things rubbing or a part very worn down. I was wondering if it could be shocks, but i think it is something in the steering or tie end rods. Any help would be appreciated. Thanks Ben I had the same problem with my legacy. When I replaced my struts I also replaced the strut mounts. The bearing in the strut mount will make noise when turning hard left, if that is the one worn. From a stand still, when you crank your wheel all the way to the left does it make noise. Like a grinding noise. If so bearings in the strut mount could need to be replaced. Quote Link to comment Share on other sites More sharing options...
Setright Posted May 14, 2005 Share Posted May 14, 2005 Brakes rubbing could be a simple as the anti-splash plate inside the wheel touching the brake disc. Come to think of it, the problem could be as simple as some dirt or stones in the spring "pan" on the suspension strut. I can't comment on prices, since I live in Denmark. I would'nt say that wheel bearing is expensive to fix. Oh, a bearing would also be noisy on the move. Are the plastic fender liners clipped into place properly? A tyre could be rubbing at full steering lock. Quote Link to comment Share on other sites More sharing options...
swc7916 Posted May 16, 2005 Share Posted May 16, 2005 I had a similar problem and the dealer said that it was the transfer duty solenoid (whatever that is). It was replaced (under warantee) and I haven't had the noise since. Quote Link to comment Share on other sites More sharing options...
