Doing timing belt... should I replace water pump?
3 replies to this topic
#1 TheBrian
TheBrian
    Eat, Live, Breath Subaru
  • 270 posts
  • Buffalo
Posted 23 May 2005 - 09:14 PM
How long's a Subaru water pump good for?
The engine in question is my '96 EJ22 with 127k miles on it. So, will the water pump make it to 187kmi? Actually, I was thinking about installing a California-spec timing belt, so the next belt replacement would be around 222kmi, a.k.a. never.
Is there a way to inspect the water and oil pumps to see how much life they have left?
#2 deiscient
deiscient
    USMB Regular
  • PipPipPip
  • 85 posts
  • Boston, MA USA
Posted 23 May 2005 - 09:29 PM
My experience so far has been that you should expect 50-75k mi from a water pump. AFA oil pumps go my original pump in my L went Tango-Uniform at 60K mi. The current one has been good ever since; no leaks when I replaced the timing belt at 120k (when I replaced the water pump as preventitive maintenance).
As an insurance policy it may be worthwhile replacing them while you have the engine face open already. New water pumps can be had for $70 and oil pumps for $130. That seems cheap versus getting stuck Bog-knows-where with a seized engine.
JM $0.02
#3 Subie Gal
Subie Gal
    GC84Ever
  • 1,451 posts
  • WA
Posted 24 May 2005 - 12:08 AM
many do water pump as preventitive maint.
also oil pump/seal/oring
try using an on line oem vendor
for huge discounts on parts
check OEM our site here:
https://www.subaruge..._parts_cat.html
(my day job)
have questions, just let me know
good luck!
Jamie
#4 Setright
Setright
    Elite Master of the Subaru
  • 3,176 posts
  • Denmark
Posted 24 May 2005 - 01:34 AM
Water pump can be trusted for two timing belts. So I would elect to replace it at your mileage.
Oil pump is strong enough to keep running. But as Subiegal pointed out, the seals between it and the engine block would be good to replace.
