regularman Posted June 14, 2005 Share Posted June 14, 2005 I have been fixing up a car for my parents and I have just completed installing my rebuilt Ea81 out of an 82 wagon into an 89 RX. I had to do some grinding on the bell housing for the flex plate to fit and its been a lot of work getting the power steering and a/c mounted up and the belts to be aligned. I finally got all that and have started on the vacuum hoses. I have a question about the auto transmission. There are two vaccum hoses coming off of it and they were loose when I got the car. Does anybody know what they do? Kickdown maybe? Should I hook them to the intake vacuum? next is going to be the electrical part Thats going to be fun. If anybody has any advice on the electrical part, I would appreciate it. Kim. Quote Link to comment Share on other sites More sharing options...
trikerab Posted December 12, 2005 Share Posted December 12, 2005 Hi everyone!! I am new to this forum ,but not to VWs and some Subrarus. I am a trike builder and at present starting to use Subarus in my trikes. I have anEA81 engine with Kenedy adaptor, I am looking for info on improvements particular carb. and electrical Quote Link to comment Share on other sites More sharing options...
NorthWet Posted December 12, 2005 Share Posted December 12, 2005 The 3AT "vacuum" hoses are probably: 1) The vacuum line to the vacuum modulator (kickdown), which runs down the passenger side of the transmission and should be connected to intake vacuum, and 2) most likely the tranny's breather tube, coming off of the top of the driver's side tranny case and just forming a downward facing loop. Quote Link to comment Share on other sites More sharing options...
NoahDL88 Posted December 12, 2005 Share Posted December 12, 2005 Hi everyone!! I am new to this forum ,but not to VWs and some Subrarus. I am a trike builder and at present starting to use Subarus in my trikes. I have anEA81 engine with Kenedy adaptor, I am looking for info on improvements particular carb. and electrical Huzzah Postus Resurectus, but i have to ask, what does putting an EA-81 into an RX have to do with putting a better carb on a EA-81 going into a trike? The "transplant forum" would be a better bet, the "retrofit forum" is for subaru into subaru. Quote Link to comment Share on other sites More sharing options...
tailgatewagon Posted December 13, 2005 Share Posted December 13, 2005 uh if its an rx then its probably a 4eat. if you need i can check the hoses on my 88 turbo wagon that has a 4eat in it... Quote Link to comment Share on other sites More sharing options...
