bgambino Posted July 15, 2005 Share Posted July 15, 2005 on the older Sub's you had to rotate the caliper piston in order to push them back in my niece has a 96 Legacy---I'm doing the rears...it's obvious that they do not need to be "screwed in"....but, do people generally just push them in with a clamp or break the bleeder screw open , then push them in? BTW--what do the fronts look like (screw in type still?) thanks Quote Link to comment Share on other sites More sharing options...
rcoaster Posted July 15, 2005 Share Posted July 15, 2005 on the older Sub's you had to rotate the caliper piston in order to push them back in my niece has a 96 Legacy---I'm doing the rears...it's obvious that they do not need to be "screwed in"....but, do people generally just push them in with a clamp or break the bleeder screw open , then push them in? BTW--what do the fronts look like (screw in type still?) thanks You don't have to open a bleeder screw, just unscrew the master cylinder resivoir. Just keep an eye on the resivoir so it doesn't overflow when you press the piston back in. Use a C-clamp and one of the pads to press the piston back in. I use a special tool you can get at any auto parts store to press it back in. The rears are single piston while the fronts are double piston. They're basically the same. A c-clamp and the old pad would work fine pressing in the double pistons. Quote Link to comment Share on other sites More sharing options...
