too high cold idle?
2 replies to this topic
#1 Midwst
Midwst
    Subaru Fanatic!
  • 373 posts
  • Cedar Rapids
Posted 22 August 2005 - 11:30 AM
When I start my 96 legacy cold, the idle holds at 1500 rpm for a little bit, unless I tap the gas pedal, but if I tap the gas pedal too soon, sometimes it doesn't drop down much. I understand the elevated rpm for cold start is normal, but 1500 is much higher than I have noticed on other cars...including other subarus. Is there anyway to bring it down...or could there be a problem with one of the sensors? Thanks.
#2 Legacy777
Legacy777
    Moderator
  • Moderator
  • 12,810 posts
  • Houston, Tx
Posted 22 August 2005 - 12:17 PM
1500 rpm is normal for cold idle. You're car is fine.
#3 Setright
Setright
    Elite Master of the Subaru
  • 3,176 posts
  • Denmark
Posted 22 August 2005 - 02:54 PM
Yep, sounds normal.
But it does seem to really hold onto the revs when cold. Tap the gas and it jumps up but takes ages to get back down.
