Suspension ??'s
5 replies to this topic
#1 Qman
    Happiness is... no lag!!
  • Moderator
  • 11,119 posts
  • Sumner
Posted 27 September 2003 - 11:11 PM
OK, I have been looking around and haven't found what I'm after.
Here's what I want to do. I want to lower my '92 Legacy Turbo wagon approx 1 1/2" in the front and 1 1/8-1 1/4" in the rear. I am also looking at adding larger diameter bars and running 205/50R15 tires. I want a firm suspension that will still provide a comfortable ride. Basically, I want the cornering to improve.
So the question is where do I find these parts and what is recommended? Strut tops? Springs/struts? Swaybars? The tires and wheels are already covered.
Thanks, Ken
#2 incognito
  • Banned
  • 441 posts
  • Eagle River
Posted 27 September 2003 - 11:35 PM
Would the RS upgrades work for the legacy chassie?
#3 Setright
    Elite Master of the Subaru
  • 3,176 posts
  • Denmark
Posted 28 September 2003 - 12:38 AM
H&R Sport springs should be what you're looking for. You might want to stick with OE dampers, if ride quality is important. However, I do mean new OE dampers, as that will make a world of difference.
Good things have also been said about Whiteline springs.
#4 Qman
  • Moderator
  • 11,119 posts
  • Sumner
Posted 28 September 2003 - 12:48 AM
When I surf for H&R springs I find that they do not offer for wagons. Do sedans work for the wagon or is it a totally different set up?
#5 Qman
  • Moderator
  • 11,119 posts
  • Sumner
Posted 28 September 2003 - 07:32 PM
Anyone have the answer for me?
#6 Subie Gal
Subie Gal
  • 1,451 posts
  • WA
Posted 01 October 2003 - 01:41 PM
heya baybe :D
sedan/wagon springs should be swappable...
but i'm not 100% if the sedan springs bolt right up in the wagon..
try asking the gang on www.impreza.net in the legacy forum
they've done it all by now!
H&R springs will drop the car a bit..
but they're too springy...
lots of bouncing and when i had em on my Legacy
i rubbed in corners (stock tires) and over speed bumps etc.
Whiteline makes a nice 30mm (1-1.5") lowering spring
SPECIFICALLY for the wagon (or so they say!)
heck... we even have em in stock :) reg $225 per set
i can make you a smokin deal ;) just shout if interested....
sway bars:
whiteline makes a nice adjustable rear bar
$125.95 - for a 18-22mm adjustable rear bar (includes new urethane bushings and a grease kit)
Strut mounts:
i'd also recommend STi heavy duty strut tops if you can find them for your car... easy to find the newer (2003 - on) but it's getting harder to get the older ones...
call me if you need help... mmmkay?
we have the sway bar and springs in stock
this would be an excellent start on your suspension woes :)
take care
