EGR system check (EA 82 SPFI) - how?
4 replies to this topic
#1 rick
rick
    New User
  • Pip
  • 9 posts
  • canada
Posted 15 October 2003 - 09:25 PM
What woud be the correct procedure when checking the presence of a vaacum on the EGR system? Should there be vaacum present on the line going to the solenid (from the throttle body) at all times (with engine running) or is there something else involved? Just checked the valve and found out that there is no vaacum present going to the EGR solenoid. Also the valve doesn't move with increased revs but causes stalling when moved manually. Any idea how do I check the lines?
On another note, just saw on a throtle body, left hand side, large sort of adjusting screw right behind the air control solenoid. Is it for idle speed adjustment? Coldn't find reference to it anywhere in the manual. Thanks.
#2 MilesFox
MilesFox
    Catch this Fox!
  • 10,686 posts
  • Madison/Milwaukee, WI
Posted 16 October 2003 - 09:57 AM
the haynes book says to let the engine warm, and once its at operating temp, give a couple of quick revsm and see if the middle part raises up about 1/8 inch.
ir use a vacuum gage and add 10 inches of vacuum and see if the middle of the egr raises.
just read up on that last night , after my ecs flashed a code 34 (or was it 42? it was late....)
#3 rick
rick
    New User
  • Pip
  • 9 posts
  • canada
Posted 16 October 2003 - 01:09 PM
I followed all instructions from the manual (Haynes) but the items in question are not answered in detail there. My problem is, that I'm not getting any vacuum to the EGR solenoid. Anyone can help with that?
#4 MilesFox
MilesFox
    Catch this Fox!
  • 10,686 posts
Posted 16 October 2003 - 05:15 PM
"The (component) is difficult to access, so we reccomend you take it to a qualified dealer or shop to have it serviced"-Haynes
i'm having the same literary troubles when it comes to troubleshooting my MPFI!
#5 rick
rick
    New User
  • Pip
  • 9 posts
  • canada
Posted 16 October 2003 - 10:39 PM
Would the fact that the rpms on idle kepp around 1200 instead of 7-800 previously have anything to do with incorrect vacuum? Just another mystery.........
