with a dvm set on 20v, connect one lead to center terminal and one lead to outer terminal and note reading ~12 = good
then connect one lead to center terminal and one lead to good ground and note reading ~12 = good
then connect one lead to outer terminal and one lead to good ground and note reading ~0 = good
then stick one lead in engine coolant and one lead to good ground and note reading ~0 = good
clean both battery terminals and connections
the cables should be at least 6ga 18"
one goes to the starter monting bolt
one goes to the starter solenoid
"FOR TESTING PRUPOSES ONLY" to hotwire a ea81 series subaru, + wire from coil + to bat. + and + wire from starter battery cable + to starter small male spade terminal
does not work for ea82
if your volt gauge goes up and down with the turn signal on, welcome to the club!
Welcome to Ultimate Subaru Message Board, an unparalleled Subaru community full of the greatest Subaru gurus and modders on the planet! We offer technical information and discussion about all things Subaru, the best and most popular all wheel drive vehicles ever created. We offer all this information for free to everyone, even lurkers like you! All we ask in return is that you sign up and give back some of what you get out - without our awesome registered users none of this would be possible! Plus, you get way more great stuff as a member! Lurk to lose, participate to WIN*!
* The joy of participation and being generally awesome constitutes winning ** Not an actual guarantee, but seriously, you probably won't regret it! Serving the Subaru Community since May 18th, 1998! |
checking the grounds AND other electrical tips
Started by
subiemech85
, Mar 13 2006 12:16 AM
No replies to this topic
