Code P0304
5 replies to this topic
#1 JBRIII
JBRIII
    USMB Regular
  • PipPipPip
  • 42 posts
  • Lousiville, KY
Posted 24 October 2003 - 05:20 PM
My wife's 96 Outback threw code P0304 (Cylinder #4 Misfire) last night after sitting at the airport for 2 days. The light went off by itself today. I ran the code when I got home this afternoon. It has also been throwing code P0420 (Catalyst below efficiency) about once every 4 weeks also after sitting for extended periods.
Is this anything to be overly concerned about?
Thanks,
John
#2 leaksoilknocksclutch
    New User
  • PipPip
  • 12 posts
  • new york
Posted 24 October 2003 - 05:47 PM
The cylinder misfire code could be as simple as moisture in the gas - if it reoccurs, more diagnosis is required. The catalyst below eff. code could be the oxy sensor after the cat converter (there is 2 on your car - 1 b4 the cat and 1 after). How many miles on the car and have the oxy sensor(s) ever been replaced?
#3 JBRIII
JBRIII
    USMB Regular
  • PipPipPip
  • 42 posts
  • Lousiville, KY
Posted 24 October 2003 - 06:14 PM
The car has 110K and to the best of my knowledge has never had the O2 sensors replaced. She bought the car in 98 with 67k
#4 leaksoilknocksclutch
    New User
  • PipPip
  • 12 posts
  • new york
Posted 25 October 2003 - 08:09 AM
I would start with replacing the oxy sensor after (downstream from) the cat and clear the codes. Drive as usual and see if any more codes pop up.
#5 color-blind
color-blind
    USMB Regular
  • PipPipPip
  • 89 posts
  • Seattle
Posted 28 October 2003 - 01:17 PM
Ignore the converter code for now. First you need to determine the misfire code. I would suspect plug wires or a failing valve/guide. It is easiest and cheapest to simply replace #4 plug wire. If you have access to a leak-down tester you should check #4 cylinder.
As far as the converter is concerned it is common for failure. Yet you have more pressing concerns with the mis-fire.
#6 JBRIII
JBRIII
    USMB Regular
  • PipPipPip
  • 42 posts
  • Lousiville, KY
Posted 28 October 2003 - 02:11 PM
Ordered some new wires and plugs. So far the code has not re-emerged. I put in a bottle of fuel system cleaner as well. I'll swap out and see what happens. Car seems strong, so it may have been an anomoly.
Thanks for all the input.
John
